iFix 5.5 initial setup
minerman
Nov 2012
Columbus, OH
82
Hello,
I am having trouble figuring out the proper Node Type and Connectivity setup for my system. I cannot find any GE documentation that elaborates on this.
I have two computers that I want to operate independently, with their own data. I want them to be on the same network exchanging data with one Siemens PLC.
For Node Type:
Should I select SCADA or View? I want each computer to act as its own SCADA system with the ability to view its own screens. I'm guessing SCADA is the correct choice, rather than "View"?
For Connectivity:
I want each computer to be on my network talking to the Siemens PLC. But, I want them to act alone and not draw data from another SCADA. I am guessing I choose "Stand Alone" rather than "Networked"?
Can someone confirm this?
Thanks.
IF U want it to be stand alone then U should select 'SCADA' as the node for both systems.
In Client-SERVER Architecture of iFix, Client node should be 'View' and Server node should be 'SCADA'. But looking at your explanation its sure that, your are not looking for Client-SERVER Architecture in iFix.
But on Licensing part of iFix, if your have the client license, then you can't use it as a Stand alone system. If you can tell me what are the iFix License U are having then I can explain it better.
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
153
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
159
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
715
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
444
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
819
