iFIX Copy Object Animation
aiki202
Aug 2007
Pennsylvania
178
Is there a way copy an object's animation settings to another object? This is a very simple task in InTouch but I cannot find a way to perform this task in iFIX. Is this possible?
Yep...saves a ton of time.
While on the subject InTouch also offers a copy/paste function of the objects themselves where once you paste the first object you position it to the offset you want from the original object...then when you paste again the next object is perfectly spaced in both the X and Y direction without needing to align (vertically and horizontally) every object you paste. Just press Ctrl + V for each additional object and...well you're done.
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
150
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
157
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
713
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
442
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
816
