iFIX Driver not reading ALL tags in a SLC5/05
svankley
Oct 2004
Tampa, FL
I have a bazaar situation where an iFIX V4.5 existing installation is now not reasding all the IO in a serially attached SLC 5/05??
If you look in the PLC database, the values are there and changing but the iFIX app which WAS running fine for months is now only showing some of the analog values and some of the digital values.
Reboot of both the PLC and PC fixed nothing!
Any ideas - this is on a booster station and is the only link to the PLC.
Steve
Look at the driver.
Has anything happened to the PC in the last little while?
What driver are you using?
It might be worthwhile to reinstall the driver.
Take a look at the iFix Mission Control. It should give you diagnostics for the I/O driver that should help isolate the cause of your issue.
Make sure your I/O driver is running and that the data blocks in question are enabled in the driver.
Are any I/O points working?
I am trying to address an analog I/O point in an S7 300 PLC with the IFIX SL4 power tool. What is the address format for the datablock...
1,083
Hello, I am converting to iFIX 6.1 and talking to a PLC5. I have several TX tags that were looking at N32 addresses in the PLC5 and were getting...
2,944
New to iFix and to the IGS driver. Environment: iFix V5.1 MODICON M340 Unity-pro V11. Memory set to Mixed Topological and State RAM. MODBUS TCP/IP...
6,562
Need help from iFix experts; Got system from integrator that is till in crates. I'm trying to run the HMI on a temporary basis (take advantage...
7,547
Morning All, A client has iFix SCADA connected via RS232 to a Mitsi PLC. The PLC has been upgraded from A-series to Q series (specifically the...
3,584
