iFix Driver Updates
Andrew Hardy
May 2010
Stockport
86
Morning All,
A client has iFix SCADA connected via RS232 to a Mitsi PLC. The PLC has been upgraded from A-series to Q series (specifically the comms cards have changed from A1SJ71C24R2 to QJ71C24N R2). I know the new comms card hasn't been configured, and I'm going to do that tomorrow. The question is if I set up the comms on the Q series card exactly as per the A series will the SCADA spring into life or do I need a new driver for iFix?
I'm not on site right now, hence can't tell you what version of iFix is running or even which OS it's running under (I'm guessing XP but it is an old PC, so may be W2000 / even NT?)
I don't know what's installed on the iFix machine in terms of alternate drivers, so where could I get a new one from?
I tried ringing GE but I was put through to tech. support's voicemail. If anyone is a UK distributor with good knowledge of iFix or a friendly S.I. I'd really appreciate some help.
Cheers
Andy
Thanks for looking - MQE seems to be an ethernet driver - the comms are good 'ol RS232. As I haven't had anything to do with the SCADA end until now I don't really know what the current driver is.
Sorted it out chaps!
For the record the I set the Q-series card to exactly the same parameters as the original A-series, rebooted both PLC and PC and it sprang into life. No new driver required - happy days.
Settings were
19200, 8 data, no parity (even), 1 stop, checksum on, write during run enabled, protocol 1.
I am trying to address an analog I/O point in an S7 300 PLC with the IFIX SL4 power tool. What is the address format for the datablock...
1,083
Hello, I am converting to iFIX 6.1 and talking to a PLC5. I have several TX tags that were looking at N32 addresses in the PLC5 and were getting...
2,926
New to iFix and to the IGS driver. Environment: iFix V5.1 MODICON M340 Unity-pro V11. Memory set to Mixed Topological and State RAM. MODBUS TCP/IP...
6,551
Need help from iFix experts; Got system from integrator that is till in crates. I'm trying to run the HMI on a temporary basis (take advantage...
7,518
Hiya - I've been assigned my first iFIX project. I've installed everything from the CD, and am far enough long that I wish to import my .L5K...
7,098
