iFix Generate alarm from boolean block
Thomas_v2
Apr 2009
Ger
519
Hello,
in iFix I want to do a boolean calculation with two values, and generate an alarm if the result is true.
The calculation in my BL block is working, and I can see the result in the database manager.
The next thing is I want to create an alarm message. When I create a DA block with a SIM address, and connect it to the BL block with next block connection, the DA block does not change the value.
If I use a DO block instead, and connect the DO block to the BL block, it's working, but the DO block does not allow generating alarms.
Can anyone give me a hint of how I can generate an alarm message from the BL block result?
Thanks, Thomas
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
151
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
158
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
713
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
442
Hi team! I'm starting some iFIX application migrations and some of them are being developed with the high performance library. Some objects that...
816
