Ignition Edge. What to Install?
ndzied1
Aug 2002
Chicago, Illinois
2,857
I have a customer specifying we use Ignition Edge. I know they are very good at letting you demo their software but I can't figure out what to download and install to start testing.
On the download page there is something called
Ignition Edge - Windows 64-bit zip
I got this but it just looks like some .BAT files that don't really do anything.
Any direction appreciated.
I sent a question in to Ignition as well. They said that I may need to install standard ignition before installing Edge.
The other weird thing was that running the start-ignition.bat file did not open up my browser. when I opened it manually with the right address then it worked.
The standard installer gives you a radio check box option:
Full fledged Ignition or Ignition Edge. The two can not co-exist.
What OS are you installing on?
It's not supposed to. It just starts the gateway.
Looks like you did everything correctly, if you can see the homepage.
We have had tons of issues sourcing replacement Panelview units, and the cost is getting worse by the year. We are looking at moving to use the...
771
Looks like I'll get a nice Winter machine programming project for one of my customers. I'm seriously looking at learning Ignition Edge for the...
2,305
Anybody know a solution to getting ignition edge to read data from a OPC DA server so that it can then transmit as MQTT (sparkplug_b) Ignition...
1,517
Has anyone tried to install and run Ignition Edge on a Beckhoff CX5100 series controller w/ 64-bit Windows 10? On paper it looks like no problem...
1,602
I find Ignition very interesting, but unfortunately it is price-wise out of my league. For comparison, I have small machines for which I use WinCC...
20
13,835
