Importing Rungs into a running Contrologix PLC
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I should know this . I would like to import some rungs into a running
ControlLogix PLC . Can you actually keep a ControlLogix PLC online and running and import Rungs into it ?
Thanks ,
Good Morning ,
Thanks ,
Yes.
Edit: All the usual caveats for making online edits apply, eg must be in remote, not just run.
I've done it plenty of times with no issues.
Edit the second: There's potential issues if the rungs were exported from a later version and you import to an earlier processor that doesn't support something in the import. I think even then it'll just fail without causing any problems for the running program though.
Adding rungs to current routine.. Copy, Paste. Create/assign all associated tags.
Adding new routine.. Import Routine.
Both are doable while online and running. the old SLCs didnt let you add new routines online.
If you do an actual import of rungs then it will create all tags as part of the import process (and will retain the values they had when exported, which can be extremely handy).
If tags in the imported rungs already exist, you will be given the option to keep the existing tag or overwrite with the imported version. 'Use existing' is the default iirc.
Hello, I have a UDT in my main RSLogix5000 program called "Servo", it consists of the following; Servo Axis01 I have an L5X (rung export)...
4,729
Hi, I'am not used to RSlogix5000 so not sure if this is a dumb question. Is there an easy way of creating the tag names when i copy and paste...
4,492
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
497
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
376
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
618
