Importing Tag Error
alive15
Oct 2015
Montgomery, AL
721
Good morning,
I have a Compact-Logix 1769-L27ERM-QBFC1B plc, using Studio Logix ver. 30.11; I want to import some tags from Keyence into my program, but keep getting errors for every tag (see image below). I'm unsure why this is happening?
I've uploaded the tag file to this link: https://files.fm/u/dte4zz9a named "SR-tags.csv". This is for a Keyence Barcode Scanner.
I noticed the version # was slightly off, but it's under a remark, so this shouldn't affect the upload, right?
Hi, I don't think you can name a tag 'SR:I'
It looks like what you trying to import is a tag data structure for a barcode module.
What you probably need to do is add your barcode interface module as a generic module named SR configured it as per manual and it will create data structure for you.
Thanks for your reply, I contacted Keyence and they said I had an older csv file. The new one looked the same, but after importing that one, it worked. I'm really confused as to what the differences are between these two csv files cause they look the same. Here is the new csv file that worked, I uploaded it to this link.
Anyways thanks for your help.
https://files.fm/u/jdwqgd4k
I have been testing the StrideLinx VPN router to replace the **** those that shall not be named. I have successfully imported variables via a...
1,230
I have a proface HMI. The part # GP-4301TM. How to you import a plc tag list to use in the HMI? I have the export tag list from my plc program...
6,200
Hello, I'm currently writing a program that is meant to write values to a specific set of tags. However, when I have a .csv file containing...
7,089
Hi guys, I am new to RSView32, I have been requested to redesign an existing SCADA system whereby a SLC 5/04 PLC communicates with multiple...
2,272
HI guys, hope you are having an uneventful Friday. I am upgrading a PV600 developed in PanelBuilder to a PV+600. I used FT View Studio ME...
2,260
