Importing plc tag list to a proface HMI file
jtashaffer
Aug 2009
KY
415
I have a proface HMI. The part # GP-4301TM. How to you import a plc tag list to use in the HMI? I have the export tag list from my plc program. Is there a way to import it to the HMI program?
jtashaffer
I don't have the software wit hme today but from memory: there are import and export facilities in the software GPproEX3.x (I think 4 has just become available but I’ve not seen it) , for Proface the tags are called “symbols”
Open the symbol viewer and there are icons for import and export. I would make a few symbols and then export them to see the CSV format. Beware, when importing the software can make duplicates if there is an existing symbol.
Chris
jtashaffer
I took a look at the software, on the Symbol variable page, at the top right its says "utilities", clik on this and it will give yuo the option to import or export, export as a GPpro and this will be a CSV file in thier prefered format.
Chris
Good Morning , I should know this . I would like to import some rungs into a running ControlLogix PLC . Can you actually keep a...
1,626
Hi everyone, Long time lurker here with a first post. Part of my tasks are recording the runtime hours on our drives here which are a mix of...
2,574
Hi, I am just new in automation field. Actually we use compact logix 1769 L32E PLC which already have Ethernet port. We also use MODBUS RTA...
4,090
I have my panelview 1000 plus on a subnet with my PLC compactlogix L32E. I would like to import the data base from the PLC into my RSView Studio...
3,541
Hey! I want to import/read I/O from PLC to VB via OPC server so that i can produce alarm sounds and such...What can I do? Can you help me...
3,716
