in particular
sheryl86_ann
Jul 2008
laguna
142
Hi!
this is the same message i wrote awhile ago. I encounter this particulat stepper motor drive and i cannot find an english manual of yka2304. the only specs i could get on its motor is stepping motor type: 57bygh450601.I dont have any further details on its specification. Somebody can help? Thanks!
A Google search came up with this
two-phase stepper motor driver YKA2304
2) with 12 / 8, the angle of stall torque constant segments, up to 200 segments
3) using a unique control circuit, effectively reduce the noise, an increase of rotational smoothness
4) The maximum response frequency of up to 200Kpps
5) Step pulses to stop more than 100ms, the coil current is automatically reduced by half, reducing a number of occasions, the motor overheating
6) Bipolar constant current chopping mode, making the same motor can output more speed and power
7) The optical isolated signal input / output
8) drive currents ranging from 0.0A / phase to 3.0A / phase continuously adjustable
9) can drive any phase current 3.0A the following two-phase hybrid stepping motor
10) single-supply input voltage range: DC12-40V
11) error protection: a) over-temperature protection; b) over-current, voltage is too low to protect
12) volume 25x136x92mm2, weight 0.3kg.
and this http://www.gravos.cz/download/yka2204ma.pdf
and
http://www.bujindianji.com/products/detail/252.html
Regards Woody
Mr. Woodygb:
Sir, thank you very much! This can help. May I ask further question please regarding PLC programming with this one:
The scenario states this way. I am assigned to replace the existing PLC of our client with Mitsubishi Fx3U in particular. The most that I can do this time since we do not have a software for that existing PLC (emerson) is to study each movement of the machine. I am just a also a beginner in PLC programming and some of which part, i am not sure yet.
My concern is regarding the PU, DR and MF addressing.
Sample addressing I used before is PLSY k680 k0 Y001 in which here, I used 680 frequency, K0 for nonstop and Y1 motor I waanted to run.
At YKA2304, is this correct that i'll used same pattern at PU terminal with PLSY k680 K0 y1 for example? What about the DR (direction) and MF (motorfree)?
I assumed direction here means the clockwise / counterclockwise rotation. Right?
When shall I used the motorfree? When I wanted to stop the motor at that particular rotation? Can you help me some sample addressing on PU, DR and MF? (Mitsubishi PLC im using)
Mr. Woodygb:
Sadly I cannot help any further...I'm pretty good at Google searches but not PLC programming.
Hopefully the real PLC experts will chip in with the required information.
Regards Woody
Sir Woodygb ^_^
Thanks still... uhmm, with regards to google search, can I asked another?
Here's my another concern: I am looking for CONTROLSTART programming software products of Emerson Network Power. What I found in the net is only the manual in pdf format. I need even the trial version of it. Existig PLC is Emerson EC20 3232BTA.
Can you help me on this road search?
Thank you very much once again.
PS: the 2nd link above is Chinese..I am Filipino, i cannot read and understand it..Anyway, thank you very much still ^_^
Sheryl - Philippines
Sir Woodygb ^_^
I can't read Chinese either ...but the Google toolbar can.
http://www.google.com/intl/en-GB/to...edium=ha&utm_term=google toolbar&tbbrand=GZAZ
http://translate.google.com/#zh-CN|en|http://www.bujindianji.com/products/detail/252.html
I usually do production support and I am the guy that comes behind someone else's program and try and debug.Often I see code that looks like this...
3,836
Here's a weird one... There's a Micrologix 1200 in the plant that uses NET-ENI to conect with the rest of the plant network. Lately, I notices...
2,401
Hello, I am writing a program which calculates the real Power and Energy Measurement and then store it inside SQL database. Now, I want to change...
1,456
How to Export Variable List for a Particular Block only in Proficy Machine Edition? I don't want the complete project variable list. Can anyone...
4,225
examples of particular application of discrete i/o modules for example in chemical industry for controlling the mixing process this particular...
2,292
R
