particular application
mariasebas
Jul 2002
dekalb
examples of particular application of discrete i/o modules
for example in chemical industry for controlling the mixing process
this particular module is used etc.
the discrete modules for which i need particular examples are:
interrupt input module
voltage comparator input module
latching input module
fast input module
rapid response I/O
relay contact output
wire fault input
So.....?
Visit the various vendor sites (Siemens, Allen Bradley, Data Automation etc) and download their documentation and start reading!
That's what any of us would have to do if we didn't already have the manual in hand.
Happy Downloading!
interrupt input module: used in telecommunications to pause conversations
voltage comparator input module: used in electrical distribution to detect brown-outs
latching input module: used extensively in door and window manufacturing, plus general architectural use
fast input module: used for high performance automotive applications
rapid response I/O: military applications
relay contact output: offshore drilling to relay info to base stations
wire fault input: I have never heard of this particular module. Tell your professor to lay off smoking the corn silk
You may want to verify these against your text and other course materials.
I usually do production support and I am the guy that comes behind someone else's program and try and debug.Often I see code that looks like this...
3,837
Here's a weird one... There's a Micrologix 1200 in the plant that uses NET-ENI to conect with the rest of the plant network. Lately, I notices...
2,403
Hello, I am writing a program which calculates the real Power and Energy Measurement and then store it inside SQL database. Now, I want to change...
1,457
How to Export Variable List for a Particular Block only in Proficy Machine Edition? I don't want the complete project variable list. Can anyone...
4,226
Hi! this is the same message i wrote awhile ago. I encounter this particulat stepper motor drive and i cannot find an english manual of yka2304...
2,084
