indexing ascii files
MAC P.
Nov 2014
st louis
17
im kind of new to the whole programming world and im trying to index a series of ascii files "A200 -> A219" these are all 256 elements long. what my boss wants to happen is we will store formula names based off of a number which we will enter into the hmi i have the range set at 0-500. the address i have to use is a floating point entry which when i tried to use it to index keeps saying cannot be indirectly addressed i dont know if its the "A" files or the "F" files that cannot be indirectly addressed. i tried to use a "N" file to see if that made a difference, with no luck... im stuck right now, and need help. i will keep checking online for solutions but i figured SOMEONE may know an easier way to index ascii files.
Hello, I'm in the process of converting a slicer from an Ultra3000 drive to a Kinetix 5100 using the KNX software version 4.00. The current...
540
Hello! The equipment I'm working on uses a lot of indexed tags I guess you'd call them. I thought it was indirect addresses maybe but all the...
1,063
Hello, Please see the attached rungs of some sort of indexed sampling routine that is currently in a SLC500. I am tasked with migrating to a...
1,293
Hi everyone. Been banging my head against a wall trying to figure out tracking on a servo driven conveyor. I already have a tracking array setup...
3,421
Phil should index or allow someone to index his forum by inserting #keywords at the end of the posts. This would make it easier to find...
1,665
