Indexing/tracking
You should be able to series the index pulse bit in with the Keyence bits. It just has to be done in the rung preceding the Multiple by 16 rung. That way once you have camera results from new capture at the beginning of an index cycle you update your status bits.
Then use an XIO to delay your timers for 1 scan cycle and allow status bits to change their state and then start timing on next scan cycle.
Remember logic is solved from left to right then top to bottom.
There will always be 4 parts every index. and currently I have everything working accordingly including the reset. I am sure if I keep looking at the code I will come up with a improved way.
thanks for your insight
@CWAL61
The above was a reply to the another post, however I see what you adjusted there as well! I will continue with what I currently have and will use this scenario if anything funky happens! I appreciate you!
Hi everyone. Been banging my head against a wall trying to figure out tracking on a servo driven conveyor. I already have a tracking array setup...
3,413
Hello, I'm in the process of converting a slicer from an Ultra3000 drive to a Kinetix 5100 using the KNX software version 4.00. The current...
532
Hello! The equipment I'm working on uses a lot of indexed tags I guess you'd call them. I thought it was indirect addresses maybe but all the...
1,053
Hello, Please see the attached rungs of some sort of indexed sampling routine that is currently in a SLC500. I am tasked with migrating to a...
1,284
Phil should index or allow someone to index his forum by inserting #keywords at the end of the posts. This would make it easier to find...
1,655
