Indirect addressing problem
omreko
Feb 2009
dubai
i want to have an FB that reads three integer values as input x ,y and z for example then set the bit DBx.DBXy.z
đź““
so, where is the problem?
If I don't remember bad, you should declare x, y and z as word instead of Integer. It seams the same but siemens have this type of things...
It will result like:
DB[variableX].DBX[variableY].[variableZ]
Don't believe that would work.
Maybe something like
Code:
L #variableY
SLW3
L #variableZ
AW
T #TempWord
CALL DB[#variableX]
SET
= DBX[#TempWord]
I would do limit checking on all data too, like variableZ must be within the range of 0 to 7.
Source code for a function as follows:
Code:
FUNCTION FC 1 : VOID
TITLE =S DBx.DBXy.z
VERSION : 0.1
VAR_INPUT
  x : INT ;
  y : INT ;
  z : INT ;
END_VAR
VAR_TEMP
  idb : INT ;
END_VAR
BEGIN
NETWORK
TITLE =
      L     #x;
      T     #idb;
      OPN   DB [#idb];
      L     #y;
      SLD   3;
      L     #z;
      +D    ;
      LAR1  ;
      SET   ;
      S     DBX [AR1,P#0.0];
END_FUNCTION
Indirect adressing
Please find here a tested function that fulfill your requirements :
TITLE =
VERSION : 0.1
VAR_INPUT
DB_Nr : INT ;
Bit_Posit : INT ;
Word_Posit : INT ;
END_VAR
VAR_TEMP
TMP_DATA_PNT : DWORD ; //Circular Buffer Data Pointer (PTR format)
TMP_DB_Nr : INT ;
END_VAR
BEGIN
NETWORK
TITLE =
L #DB_Nr;
T #TMP_DB_Nr;
OPN DB [#TMP_DB_Nr];
L #Word_Posit;
SLD 3;
T #TMP_DATA_PNT;
L #Bit_Posit;
OD ;
T #TMP_DATA_PNT;
SET ;
S DBX [#TMP_DATA_PNT];
END_FUNCTION
Hi all, I need to move in the same DB 32 bytes from DBB00-DBB31 to DBB32-DBB64, so I have tried to write a simple code using the indirect...
2,195
Hi guys, Disappeared few weeks for writing code, I'm back with a problem. There is a repeating work for different group of signals, so I decide...
18
15,149
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
623
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
670
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,383
