Individual Register Mapped to an Array Element
Or, in the CompactLogix, map 28 different tags to 28 different data table numbers.
MLX_Data_1 will be an INT[2] array tag mapped to Data Table 10
MLX_Data_2 will be an INT[2] array tag mapped to Data Table 11
MLX_Data_3 will be an INT[2] array tag mapped to Data Table 12
and so on.
Then each MicroLogix sends its data to a destination address of N10:0 or N11:0 or N12:0 (and so on).
You're going to have to change the addressing in each MicroLogix program to be specific to a different destination address emulated by the CompactLogix no matter what.
and so on.
That is what I will do. Thank you for your help!
That error confirms your investigation into the feature: you cannot "map" a Data Table Number to a sub-section of an Array Tag.
The "Map PLC/SLC Data Table" feature is definitely a 1:1 relationship between the entire INT or REAL array type Tag and one PLC/SLC Data Table number.
Hello, Its my first time working a project that involves PLCs. I need to develop a way to track parts with serial numbers that are passing through...
5,305
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,147
I am passing DINTs between a Micro800 and CompactLogix - each bit in the DINT has its own unique meaning. On the Studio5000 side I can just write...
1,109
Hello, is there any way to address individual bits in ReadTag/WriteTag? I am using PV800 with L33 processor so I have almost reached the 400 tag...
670
In my current place of work, some of our lines have a lot of E-Stops and safety devices scattered around and if one of them acts up or we have a...
2,331
