Indramat PPC comms - CoDeSys OPC
Manglemender
Jul 2007
Lancashire
1,295
Greetings all,
I'm hoping someone can offer some advice as heads are being scratched.
I have a project that requires two SCADA systems (RSView32) to communicate with one Indramat PPC controller via the Indramat (CoDeSys) OPC server over ethernet with TCP/IP.
It seems that all comms to the PPC must go through an SCP gateway server; Connecting more than one SCP Gateway to one PPC causes the comms to fail.
It ought to be posible to route the comms from the second SCADA through the SCP Gateway on the first SCADA system via a Remote SCP connection. I've tried setting this up but cannot get the remote connection to work despite folling the guidance of the help files regarding DCOM settings.
Has anyone done this before? Can anyone offer a better method?
Best regards,
Nick
As you state only one connection is allowed via the SCP.
You can use multiple direct ethernet connections. In the opc configuration use the option "TCPIP Level 2 route (PPC)".
If you are using Indraworks there are a number of system libraries within CoDeSys for setting up a direct socket connection to a host. If you don't have them call your Rexroth support team.
I am NOT familiar with the PPC but know this is available with the MLC controllers. Originally tried the OPC interface and ooooohhhh sooooooo sloooooooooow.
With advice from Hokie I do now have two SCADA systems speaking to one PPC controller but it is quite slow; but for now, at least it works!
Nick
hi everyone! we need to update the program in the servo, a Rexroth Indramat PPC-R02.2N-L. The thing is we need the software for it, WinPCL...
787
I recently received some Indramat PPC's to replace Indramat CLC's and am having issues with transferring the programs form one to the other. The...
1,784
Hi, I'm trying to set up communication from a indramat ppc r22.1 to a phoenix contact plc using interbus. I don't know where to start...
2,725
Hello, Can anyone help me to find Rexroth INDRAMAT PPC-R01 controller GSD file called INDM04B0.GSD? I had not any luck to find it on the...
6,867
Hello, what program is it used to connect with laptop a rexroth indradrive HDS02.2-W040N-H(verry old model), i'm guessing because its old so on a...
1,327
