Indusoft reports
manasi
May 2007
maharashtra
123
Can anyone advise me on Indusoft report generation. I am not able to do that :( Actually I have tried once but it does not show value in real data format...it shows in integer format. While the tags are defined with real data type.
-Manasi
From the help on reports:
"For Real type tags, use the following syntax: {tag_name n}, where n is the number of decimal characters you want printed."
Hi, Thanks...now i am getting values in real data format.
One more help need from you. hope u will not mind.
Generated csv files doesn't show column headings. like...Date, Time Value etc.
I have attached some snap shots of report settings. Kindly see them and advise.
Regards
Manasi
Hi all, I have created a report using a report writer in Indusoft scada, but i just wanna know can i import the Bargraph symbol which is...
1,213
Hi, I have to modify a client's aveva edge application and I'm not sure how to download the modifications without breaking anything :) Setup...
306
Has any one used IWS 7.0 on a Win 11 Pro machine? Cant find a compatibility chart.
457
Is there any easy way to store a password for an email address that is changeable on the HMI that is not easily deciphered. aka, don't write it to...
385
Is there a tool to convert or import an Indusoft HMI progect to a Factorytalk project?
1,198
