Injection Molding
new at this, I have a Negri Bossi injection molding machine. What are some things that I need to provide? Thank you
Have you talked to the manufacturer, that would be my first point of call.
Basic info would be has it got a PLC or HMI in it or does it use a propriety controller ? If it uses a PLC/HMI what type is it ?
If it's like a Husky, or a Krauss Maffei, it's going to be a proprietary locked down system. You will have to contact NB to get them to provide an interface for you.
You'd need the project for the B&R PLC and use the email function to send SMS through either a 3rd party service or the carrier's email to sms system. They definitely won't give you the code for the PLC for a system like this, so you'll have to pay the OEM to add that feature for you.
about 10 yrs ago I was asked to do this with a Mazak work cell. I don't recall the brand but all we needed was a signal from an alarm(light) to trigger the call/text. I think it was less than $500. Worked well for us.
I did this too. Used the xenon beacon signal to trigger a relay that then triggered a texting box. It can text up to 10 numbers each time there is a fault and it also sends a text every day to say all is ok. The box was 80 quid + a 5 quid a month SIM.
As mentioned above. Either take the alarm lamp signal or get a cheap programmable relay, like a Siemens Logo to collate if you want more than 1 digital signal and output to the linked above.
Don't waste time with the OEM.
Heat/Cool – First Experience Although we have extensive PID heating experience for thermoplastic injection molding, today we are faced with a...
2,100
anyone have sample program of Pro-Set 200 from Allen Bradley? or any other injection molding sample? i'm struggling on upgrading old injection...
1,563
I am trying to locate a servicing company both for parts and for Mitsubishi FX2 Plc access codes. I do not want to know how to crack the code...
2,469
Hello all, I have a project to upgrade an injection molding machine that someone else has started and went bad. (Mainly the controls for the...
3,724
I have an injection molding machine with a ge fanuc 90-30 and I back up the program with LM90 but I can't see the ladder program to monitor the...
2,661
