Inserting S7 connection not possible in CPU315-2DP 2AF03
Plc_User
Dec 2005
Belgium
317
I would like to run a test for Simatic net Opc-server between pc en cpu 315-2dp 2af03.
For that I have to set up hardware of the plc that in Netpro I insert an S7 connection, either an unspecified connection or a connection to the opc-server if it is in the same project.
I would like to run the communication over mpi of profibus, so no ethernet card is inserted in the plc rack. But I don't succeed to insert an s7-connection in the plc?
I only succeed if I insert an ethernet card in the plc rack in hardware config, but I want to use mpi or profibus.
Its been a while since I've set this up
But it should work. Can you post some screen shots of netpro and
The profibus cp card your using in the pc
Also a screen shot of station configuaration manager
I've not used the OPC stuff but I managed to get the following.
When I created the hwconfig with the 315, I networked the Profibus port before opening Netpro.
Thanks for your replies.
I made the mistake I wanted to make the S7-connection from the cpu, but you have to do it from the opc-server.
Everything works now.
Hi Guys, I am running an ABL33ER on firmware 33.12. I noticed that when I insert the SDcard into the controller the program stops. Not only that...
1,861
If you attach more than 1 photo. They do not show up in the body of the post? Is that a limitation or am I doing something wrong? Thanks, Dave
1,402
Hello, I'm new to AutoCAD and had some questions. If I make a border at roughly 8"x11" or something like that... How do I insert something that...
3,338
Morning all Using Studio 5K v 29 Lets say...........engineering changes a design :shoot: I started my I/O tree and now I needed one more...
1,560
How would I search an array of 52 SINTs for an available space (0) then move a (1) into the first available space?
29
9,828
