installation problems
sunnyvaleplc
Sep 2009
sunnyvale
I am new to PLCs and so please pardon my ignorance.
I am trying to configure a compactlogix system. The controller is L32E.I have the controller, the power supply and the end cap attached. At this time I do not have any I/O modules attached to the controller. As soon, as I apply AC power to the power supply, the controller starts up but the OK led on the controller is flashing ( Amber in color).
I read in the manual, and it says the controller needs firmware update.
I configured the serial drivers successfully, and I am trying to update the firmware. The problem is that the "UPDATE FIRMWARE" button is grayed out, and I can't use it.
What am I doing wrong.
Any help will be appreciated.
Thanks,
sunnyvaleplc
As a side note - it would be less risky to achieve communication using the Ethernet port. If you do upgrade the firmware it will take much shorter time thue being less subject to problems.
Hi everyone, I'm looking to get into Ignition, so I downloaded the latest and greatest installer from their site. (v7.9.10) When trying to...
3,202
Hi All I am trying to update my communication driver for PLC/HMI communication via DH+ to ethernet/IP. I have an automation PC that is running...
3,125
I am currently trying to install WinCC Flexible 2008 Standard on a windows 7 32-bit machine. In theory this should be straight forward however the...
11,875
C
I am having an issue install Factorytalk View ME 6.10 on my computer. The error I am getting is that it says I am having to install FT Services...
2,498
CheezyMane13
C
Hi All, as i have experienced few problems in my activatation after my OS installation. i decided to uninstall all the rockwell related softwares...
1,375
