Intellicenter Motor Control Center
mday
Dec 2003
Tennessee
58
Hello, I'm doing some research on motor control center and wonder if anyone has a rule of thumb with the difference in using a Rockwell Automation Intellicenter with DeviceNet instead of Ethernet IP. Have you seen a price different depending on the type of network being used? I know the advantage of Ethernet IP over DeviceNet, just wondering if the added capability of Ethernet IP out weighs the cost if different. Thank you
We are looking into installing an etherneted Intellicenter at my place of work, and using either a compact logix, or control logix platform for...
1,585
I have added two new buckets into an existing MCC. I have setup the nodes and I can see the new E3's in DeviceNET. I am needing to get the...
2,184
Gents, I have a customer that is installing an Intellicenter Devicenet MCC and it is going to have a Ethernet/Devicenet Bridge on it. I have...
2,521
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
287
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
237
