Intelligent Modbus Gateway Required
Well. Post #12. One small PLC between original PLC and equipment.
Then on post # 13 OP asked how it would poll 16 devices.
I guess you are not getting the point here regarding the scenario. Let me try again here:
In principle, every PLC com port will have a unique Modbus Address. Right?
How will a new PLC read 16 different Modbus Slave Address Requests via a single com port from existing PLC? I am unaware of any PLC that can respond to multiple addresses via a single com port. I hope its clear what we are trying to achieve here. Anyway Redlion Datastation can do this job as confirmed by their technical support. So I am going with that.
Additionally as danw pointed out. I posted same question on another forum and there are two more suggestions there. Below is the link:
Two additional solutions offered here:
https://control.com/forums/threads/i...equired.49384/
You are right, it should need 16 different slave ports.
Changes are that there isn't much devices to choose or you need 16 different parts or some other devices between.
Why original PLC modbus master program can't be changed?
Anything with 16 ports can do the job. But that's not an effective solution. That is where Redlion Gateway will be handy. I have not tested it yet, but I have been told by an expert that it can do this job via a single port.
Actually PLC was installed by a vendor who is not giving access to PLC logic project for modifications so we have fixed addresses and registers from PLC side and have to change obsolete field devices via a gateway.
Modbus is transmitted over serial lines between devices. The simplest setup would be a single serial cable connecting the serial ports on two devices, a Master and a Slave. The data is sent as series of ones and zeroes called bits. Each bit is sent as a voltage. MODBUS is a commonly used industrial communications protocol. It allows the exchange of data between PLCs and computers. It was originally designed for Modicon (Schneider Electric) PLCs but has become widely used by many PLC manufacturers and industrial networks, Thank You!!
:confused: Errrrrrmmmm OK. Have you read this thread and the OP's question ?
Hiya. I'm a bit of a newbie to PLC's. I need to configure the MODBUS without the use of the intelligent function utility. I have followed the...
2,831
I just graduated as a mechanical engineering student, and started this new job a controls specialist with a company in my area. My coworker has me...
966
MELSEQ "intelligent modules" configuration, programmatically resetting the CPU Hello. This is for the Mitsubishi experts, and thanks in advance...
1,063
Haven't done much with soft starts, more-so VFDs' in my time. Looking at replacing 3 x 37KW (415 V 50 Hz) star-delta starters with soft starters...
2,876
We have an old punch press machine. Many years ago (probably around 1990) a machine builder called Steelcase Inc (currently not in machinebuilder...
1,558
