AlfredoQuintero
MELSEQ "intelligent modules" configuration, programmatically resetting the CPU
Hello. This is for the Mitsubishi experts, and thanks in advance for some advice.
The first part of my question is asking for confirmation of my understanding with regards to the so-called "intelligent modules" which in Mitsubishi lingo basically means network and motion control backplane modules. The Mitsubishi Electric engineering tools (GxWorks3, GxWorx2, GxDeveloper, etc.) have special property pages for the configuration of these boards. Also there is an option to configure the board in the PLC logic directly, and this is used when the configuration of the intelligent module needs to change frequently, as this mechanism has the advantage of making it possible the re-configuring of the intelligent module by simply remotely stopping and setting the PLC in RUN again with the engineering tool. For example, the old MELSEC A were programmed like this, and the those old boards had relatively few parameters, such as the IP settings of Ethernet boards.
Now, when the configuration in the special property pages is used, saving the new configuration of the intelligent module and downloading the program, then starting the CPU, won't do the trick, as the configuration is stored somewhere else, so the new configuration of the intelligent module will not be loaded until there is a power cycle or a hard-reset.
I cannot find a way to do a hard-reset remotely with GxWorks3. If there is one my problem is solved, but after years of working with Mitsubishi I have not been able to find one. But I have not asked either, so there may be one and disabusing me of my ignorance will be great.
If the above is correct, then the second part of the question is whether there is a way to programmatically reset the CPU by means of SD register somehow.
I am using a CC-Link IE TSN, and configuring that card by logic seems to be way too complex.
