Intellution Fix V7 and Siemens S7S200
Graeme
Guest
G
Has anyone ever found a of getting a Siemens S7 S200 to talk to Fix 7?
It seems to be one of the few plc's that a driver isn't available :(
FIX must be able to talk "OPC".
So you need an OPC server from Siemens or a 3rd party supplier.
Be careful to get an OPC server for S7-200 and not S7-300/S7-400.
Ken your right Fix32 Cant use OPC.
I can get an OPC server to talk to FIX32 but then I'd need an OPC server to talk to the PLC. Gets a bit messy and expensive
Do you mean that you can add OPC client functionality to FIX, but it is an option you have to pay for ?
Intellution dropped development of the FIX32 line after porting it to Win2K (Version 7). They are encouraging all customers to migrate to iFix (current package).
OPC compliance was never developed for the Fix32 package and a third party OPC client must be purchased. Such as this ONE. Then an OPC server must be obtained and installed.
I looked into it several years ago, around the Y2K event. Seemed overly complicated, so we just migrated to iFix instead. This is not a straight forward task. Fix32 appears to have been written in C, and iFix is more like Visual Basic. You basically have to redo the entire project.
Ken
hello guys following errors ocurrs during trying to starting mission program 1. workspace.exe has generated errors and will be closed by windows...
1,540
I am currently working on rebuilding a computer that had Intellution iFix 3.5 on it. The original installation disks have gone missing and unable...
2,527
Hello, I am receiving a runtime error in my Intellution IFIX 3.0 as follows: Runtime Error '-2147200630(8004518a)': Automation Error can...
3,373
Hello, I am using the iFix Scada version 2.5 and i am facing a problem. Once i open the PC and try to open iFix i get a message that the driver...
2,747
Hi every one, I know this may sound pretty basic for some of you but I'm absolutly new to the intellution Fix 7.0 "SCADA". The software is...
2,462
