Inter PLC Communication over FINS Protocol in OMRON
Oct 2019
Rajkot
Hello there,
I am new to OMRON PLCs so need some help to communicate two PLC over FINS Protocol.
Here are the description of the system...
PLC1-
CJ2M-CPU33
IP- 10.113.218.34
SUBNET-255.254.0.0
UNIT NO - 00 (set the dial available on the CPU in HEX)
NODE - 22 (set the 2 dials available on the CPU in HEX)
PLC2-
CJ2M-CPU33
IP- 10.113.218.35
SUBNET-255.254.0.0
NODE - 23 (set the 2 dials available on the CPU in HEX)
Now, what i have to do is to transfer the D100 to D110 from PLC1 to PLC2's D200 to D210 and Transfer the D100 to D110 from PLC2 to PLC1's D200 to D210 over FINS only and not on Ethernet/IP.
I have tried RECV and ECHRD blocks but didn't succeed yet.
Two CPU are connected over ethernet via a industrial switch.
IO table screenshot attached, same for PLC1 and PLC2.
i have dvp 14ss2 plc and kgk inkjet printer .how to send data via rs232 com port,and if any sample program available please send .
2,080
I want to print Recipe name in labels from a Rockwell PLC using a CAB printer. I can use an Ethernet gateway device to transmit the command string...
5,105
Hello All Yesterday a friend asked me about to create a communication between the PLC and a printer... He wants to use it in an application that...
11,863
Hi All Trying to get the PLC to send a commant to the printer to prinnt a lable. evarything is setup except RS linnx cannot see the printers and...
398
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
383
