Interface between PV1000 and LGX5000
jackhenkel
May 2012
Grand Rapids
62
How do I interface a tag from PV1000 to a Logix 5000 tag? My flow of information should go from PV1000 through a DHRIO module then to my Logix5000 program and vice versa.
What is the full part number of the PanelView terminal ? That will tell you if it is using DH+ or RIO protocol.
The exact firmware revision of the PanelView terminal, and the revision of PanelBuilder software you are using, are important as well. DH+ access to native ControlLogix tags was added piecemeal to the PanelView Standard over several years.
I don't have the panelview terminal in my possession so I can't tell you the full part number. I have my logix5000 program and the terminal program. I want to create a discrete I/O tag in logix and have it talk to the terminal. Why is this so difficult, I can't find any info anywhere on this?
Dear Experts, We have two PLC independent PLC panels with two independent controllers , we need to make hardware splitting for some AI and DI...
1,033
Hi Friends, I'm making a PLC operated chocolate vending machine, using a CLICK Basic PLC (C0-00DD2-D) which has 2 x RS232 ports. I'm also using...
1,535
Hello all, I am a beginner in PLC programming .I am working with Beckhoff PLC and now trying to integrate Mitsubishi robot to the PLC. Mitsubishi...
4,927
We have requirement to integrate SLC 5/03, Micorlogix 1500 and S7-300 PLC with common HMI , either Woderware or any other HMI. Any one has got...
1,814
We have requirement to integrate SLC 5/03, Micorlogix 1500 and S7-300 PLCs (which is haveing independent HMI) with common HMI through Ethernet...
1,441
