PLC Interface between SLC 5/03,Micrologix and S7-300
abhargava
Sep 2006
Bangalore
We have requirement to integrate SLC 5/03, Micorlogix 1500 and S7-300 PLCs (which is haveing independent HMI) with common HMI through Ethernet, either Woderware or any other HMI. Any one has got this type of application implemented. Any ideas?
Hello abhargava.
If I understand you correct, then you want to connect several PLCs to one HMI, and the HMI is PC based.
Almost any modern HMI/SCADA program will do. With OPC you can connect to basically anything that has an OPC server.
Dear Experts, We have two PLC independent PLC panels with two independent controllers , we need to make hardware splitting for some AI and DI...
1,033
Hi Friends, I'm making a PLC operated chocolate vending machine, using a CLICK Basic PLC (C0-00DD2-D) which has 2 x RS232 ports. I'm also using...
1,535
Hello all, I am a beginner in PLC programming .I am working with Beckhoff PLC and now trying to integrate Mitsubishi robot to the PLC. Mitsubishi...
4,929
We have requirement to integrate SLC 5/03, Micorlogix 1500 and S7-300 PLC with common HMI , either Woderware or any other HMI. Any one has got...
1,816
We have a AB PLC-5/40 hot back-up system with 1746 Remote I/O and would like to interface Cutler-Hammer Westinghouse IQ-1000 II, IQ Data Plus...
12,254
