abhargava Member A Join Date Sep 2006 Location Bangalore Posts 2 Sep 6, 2006 #1 We have requirement to integrate SLC 5/03, Micorlogix 1500 and S7-300 PLCs (which is haveing independent HMI) with common HMI through Ethernet, either Woderware or any other HMI. Any one has got this type of application implemented. Any ideas?
JesperMP Lifetime Supporting Member + Moderator Join Date Feb 2003 Location ᚴᚬᛒᛅᚾᚼᚬᚠᚾ Posts 16,376 Sep 6, 2006 #2 Hello abhargava. If I understand you correct, then you want to connect several PLCs to one HMI, and the HMI is PC based. Almost any modern HMI/SCADA program will do. With OPC you can connect to basically anything that has an OPC server.
SNK Member S Join Date May 2004 Location Toronto, Ontario Posts 885 Sep 6, 2006 #3 If it is an AB PV+, then you can use Kepware Server to get all of the PLC's working with the same HMI.
