Interfacing an LCD with mitsubishi FX2n PLC
mashood
Oct 2007
islamabad
Dear fellows,
I am interfacing 4 line VFD display with mitsubishi FX2n PLC using transistor output module. The output transistor module is open emitter rather then open collector. Please guide about the hardware interface between Display and PLC (Display is conventional 4-line display with 8 data lines, one RS, one R/W and one Enable line).
cheers,
Mashood
Never heard of such a thing. Are you sure the FX can support it? Most of those devices I've seen are serial communications based, and that would not be using PLC outputs.
I know what you are trying to do, however plc's are not very good at fast scan on digital outputs to load a binary pattern onto outputs & then strobe the lcd.
The update of the outputs will be slow in terms of using them to map an lcd display if you do not mind the chars refresh rate to be like a scrolling display.
assuming this is an industrial application it would be almost as cost effective to use one of the propriatry text HMI's
After you have built the interface, larger plc to cater for the i/o required for the display etc.....
I agree with you. In fact, I am creating an HVAC system and HMI will definitely increase the cost as compared to a cheap LCD display. I am trying and i hope to make it. Any suggestion in this regard will be welcomed,
Cheers,
Mashood
Cheap HMI
Cheers,
Mashood
Mashood
Look at my HMI for the Mitsubishi priced at $179. You can run my HMI on a cheap laptop.
Download a demo here:
http://dwhylton.com/Sellwood2n.htm
Doug Hylton
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,263
Hi, I am picking up a project started by a predecessor who is now out of contact. It is a Siemens S7-1515F PLC system - but the query is how you...
763
Hi everyone, I've got to interface 4 x Mitsubishi Q series PLC's with an Allen Bradley Compact Logix PLC using a Red Lion Data Station DSPLE000...
514
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,070
Hello I am very familiar with ladder logic and PLC programming, however I am new to Allen Bradley, ethernetIP, and interfacing measurement...
1,040
