Interlocking diagram
Lesa
Sep 2006
Novi Sad
71
Is there some standard for making interlocking diagrams?
I have to make some interlocking diagrams for plant that makes compost.
Interlocking diagram, in our terms, should say if some mashine goes off because of a problem or some other reason, which mashine should PLC software switch off.
Thank you.
I am not aware of anything internationally recognized, though that is not to say it's not present. The company I work for has a group who defines these as corporate standards that we follow. Mostly, these vary greatly from machine to machine. What is standard and does not vary is the process that is used to identify what hazards must be protected against, and what methods to use to protect against these hazards.
What type of diagrams? Electrical? P&ID's?
On P&ID drawings, I put a diamond with a capital "I" and a number on the interlocked device, and the initiator device also. Then in the drawing notes, I put the diamond again, with text describing the interlock. Something like:
When temperature transmitter TT-100 exceeds 100 C, control valve TV-100 will be interlocked closed, and cannot be opened until TT-100 drops below 95 C.
Thank you.
Understand the requirement is digital process application.
The logic requirements can be prepared
1. In the form of write ups which explains the sequences of start up, preconditions for respective equipment/process, interlocking requirement for announciation/trip to take care of safety requirements and safe shut down of the equipment/process.
2. NEMA or SAMA/ABMA standards have symbols for gates like AND, OR, NOT etc. These symbols can be used for preparing the interlog logics
3. Can also be prepared in ladder logic form which is used in PLC programming.
R.Thiyagarajan
thanks frnds for your response.My question is ": what is interlocking and how it works in plc program,plz explain.
1,890
I have a function where I have set it to qty interlock, how should i interlock it in the motor block ... :huh:
1,104
I just have a little task I’m trying to complete, and I wonder if anyone has any suggestions. I have a crushing operation running with 3 separate...
2,078
I have 2 Logix based systems that I need to Interlock together and read and write data in both directions. In the compact Logix system I have the...
2,276
Please guide me to do interlocking of my hydraulic power pack system during line stop for more then 10 min condition in simatic manager system. I...
2,276
