Internal bell problem [alarm sound]
I have the same problem, [and] if you already solved it, please advise
Mohamad, read Post #12 in this same thread:
I found the place to activate [the] alarm sound for Alarm&Event. Just double-click your alarm and event banner, then go to the states tab and check [the] "Sound" box.
Use the .InAlarm or .InAlarmUnacked bools in an XIC instruction to drive the output with your audible signal.
Thanks rdrast for reply.
But i want to configure 3 severities of alarm (Low, Mid, High) and hooter/buzzer should be activated for high severity alarm.
your suggestion will work definitely but quite lengthy for approx. 500 alarming system. so is there any way like HMI server in A&E server to activate external hooter.
Thanks in Advanced.:nodi:
No.
Do it once in structured text, copy that into an external editor, then copy/paste/replace wisely 500 times.
Gostaria de saber se alguem pode me ajudar.
Meu problema e o seguinte. Criei meus alarmes em Alarm e Event Setup.
Quando acontece um alarme gostaria que gerasse um som neste alarme quando o alarme vai para o sumario.
Does anyone have a clue on how to increase the loop time of the alarm internal bell? Thanks, Max
1,214
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
307
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
391
Kindly, we are having a problem on a machine during night shifts, while no engineering tool is online. So, we were thinking of programming some...
771
Hello. If anybody has seen this before and could provide some clues I and some other people would be extremely grateful if you can share such...
1,353
