Intouch 10.6 132 Character Tag Limit
SeanWRT
Jun 2016
Windsor, Ontario
17
Hello fellas I appreciate your time.
I am QUITE new to the world of PLC again and starting a new venture. I am working with InTouch 10.6 and I am asked to get around the 132 character limit of tag data.
I am currently trying a few things.
1. ActiveX to the database directly.
2. Supertags
3. SQLSetStatement
1. ActiveX was tried and nobody really liked that solution.
2. Supertags seems to interest me but I am having problems understanding how to bring all the tag data from the child tags together. Any help would be greatly appreciated.
3. I found an Intouch document online that stated to use a SQLSetStatement to insert the tag data after it has been concatenated.
How many of you have done anything like this and would you please share your experiences?
Thanks and have a great day,
ST.
Thanks Garry, I'm going to look through those threads, I didn't really know how to search for what I was looking for, but I did try and found a few threads.
Thanks again!
S
Thanks fellas, I figured out the code. That was part of the problem. I created Variables and inserted them into the syntax as opposed to the entire tag names.
Thanks,
Administrators, please close this thread if you wish.
ST
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
93
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
