Intouch Fault Logging Problem
zeus_eng
Dec 2005
Ontario
Hello everyone,
I have been pulling my hair out with this strange problem.
I have intouch 5.0 running on many machines on our production floor. Just recently we have decided to perform fault logging to create a database of fault occurances. I have enabled fault logging on the machines through:
Special -> Configure -> Alarm Logging, in windowmaker.
We would like the log files to only be held for 30 days, and this has been specified in the settings. However, regardless of the number of days specified, log files are only held for 2 days unless 0 days are selected. I do not want to manually delete the files and use 0 days (this keeps logs indefinately) selection as this would require a full time job in itself.
Any help on this matter would be appreciated.
Thanks,
Zeus_eng
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
90
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
