InTouch Realtime Trends
Furbs
Sep 2013
USA
34
Hey guys, I use this website all the time for PLC help, but this is the first time I've actually had to post something.
I am using InTouch 10.5, not Archestra, and trying to make generic PID popups to be used for all 150 PID loops. In the past, unique PID popups have used, but this time I am trying to avoid it. We want to be able to open many popups at a time.
Currently I am using indirect tags with a dynamic referencing to move the appropriate tags to a PID_1, PID_2, or PID_3, etc holding variables. The largest issue I am having with this is that I just realized that the realtime trend keeps logging the value of the last PID that it loaded. So that when you pull up the trend, it will show the value from the previous value loaded and then start updating.
My question is: Is there a way to start with a clean trend or reset the trend when I open it? Otherwise I will have to go back to using unique popups. I like having everything dynamic, so I really don't want to do that.
Also, if anyone has any tips or tricks to making 1 popup used multiple times, I would appreciate it as a bonus. I have a method that I think I can iron out, but I seem to keep running into InTouch limitations. It has been hard to search for answer now that everyone has moved onto Archestra. (yes we are talking about upgrading to Archestra as well)
Thanks all
In this situation I would use a historical trend and just update it every second from the while showing script to make it behave like a real time trend.
Just set the pens using indirects on show.
You are on the right track, just some fine tuning to get there.
There are a couple of ways, send me a pm & I will dig out an example over wknd.
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
90
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
