Intouch, textbox and long text of the SQL
karel.laska
Aug 2012
Radvanice, Trutnov
Hi there ..
I have a question related to InTouch. Because my English is not good, I hope I explain well.
In a project using wwGenericSQLGrid (ActiveX) and after selecting the line, insert a value into the textbox. When you use a variable transmission InTouch, everything is OK.
The problem is that the value stored in the SQL DB and the text is long. (131 more characters)
I tried to save the results to a file selection, but it fails.
It would help if the value will be entered directly into the textbox ..
or
It would help if I could write the selected line to a file.
or
Using another ActiveX control such as DataList in ASP.
For your ideas thanks ..
Once again sorry for my English.
Regards Karel Láska
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
143
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
134
174
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
108
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
153
