Intouch V10 Momentary button with Windows 10 Touch Screen
jonney
Apr 2012
Malaysia
70
I have a Window with few Pushbuttons set as Direct. There's no problem using mouse clicking. But on touch screen monitor, the button behavior is different between mouse and finger touch. My finger have to touch and MOVE a bit to activate the button. My expectation is that my finger touch then get momentary response. Any Work around on intouch side or Windows 10 side?
FYI, wonderware had an article, but I am not sure whether it matchs my matter.
https://knowledge.insourcess.com/Wo...ows_10_Touch_Screen_computers_such_as_Surface
Really basic suggestion here but have you tried to recalibrate the touch screen? I don’t know your hardware but I’ve never seen a touch screen that couldn’t be recalibrated.
I don't think the calibration solve the problem. Have you read the article?
I have done few tests on different PC with different touch screen. The problem remains the same.
I found ONLY the push button's Action set as Direct got such problem. Others Action such Toggle/Reset/Set have immediate response. I have to hold and move few mm then the button got response.
I write the script on Pushbutton's Action:
On Left Click/Key Down: tag=1
On Left Click/Key Up: tag =0
The problem remain the same either PLC on line or offline. I think it is Wonderview's native problem on Left Click with touch screen.
Possible reason is that view.exe is mess with "On Left Click" and "On Left/Key Up" with touch screen.
Use a different touch screen driver then the one that comes standard with Windows. There undoubtedly is one that will work with your screen, and they provide much better features and control then the default windows one.
One of Touch monitor is Acer UT220HQL. I have installed Acer driver, but the problem remains the same.
If you are convinient and are interesting, you can make a demo with a pushbutton to test it. I think it is Wonderware software problem.
intouch_PB_problem_1.PNG intouch_PB_problem_1a.PNG intouch_PB_problem_1b.PNG
Typically we make buttons like this 'Set' action. In the program there is a line that goes: if that bit is on, do something, then unlatch that bit. That might be a suitable workaround for you.
Thanks.
Solution is cheap. My post is providing information for others in case they searched.
If any body has SP2 for InTouch V10.0 , Could yolu please send me the setup file. Thanks yolu very much for your help.
1,219
Hi All, i have an Client with a old Intouch V10.0 installation, now i am trying to setup a new development station but the active x menu bar used...
1,110
Just helping out a local voluntary organization that has a small dryer to dry food to send to communities/countries in need of food. They had a...
2,014
Anyone know how to pull a list from the tagname dictionary for the purpose of viewing or printing the alarm priorities? I have been diggin and...
3,470
I have 2 HMI computers bother running InTouch V10.1. One of the computers is in the MCC with the modicon quantum PLC. The other is a field...
22
7,026
