Intouch Wonderware V10.5 Tagname Dictionary
djcarter
Sep 2014
Tennessee
21
Anyone know how to pull a list from the tagname dictionary for the purpose of viewing or printing the alarm priorities? I have been diggin and cant seem to figure it out.
Have you done a database dump? This gives you the tagname configurations.
In the "Application Manager" directory (Intouch icon), highlight the configuration name and select "DBDump" and follow instructions.
This gives you a DB.csv file (default name but I usually rename to the <application name>-<date (ie...091914>-D1.csv) which can be viewed and edited in Excel.
If you edit the database and want to reload make sure you change the first line of the CSV file from "Ask" to "Replace" (no quotes).
If you edit the actual tagname it will make a new one, otherwise all changes will be applied to existing tag.
Save original database dump, so you can reload if errors.
I have 2 HMI computers bother running InTouch V10.1. One of the computers is in the MCC with the modicon quantum PLC. The other is a field...
22
7,023
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
159
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
169
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
431
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
196
