Intouch v7.x to 9
theDave2
Aug 2004
Rochester, NY
467
How do you convert a version 7.x Intouch application to version 9? When I try to open it in Window Maker, via Application Manager, it gives an Access Denied message.
Actually, I only want to import some windows, alas in Window Maker it get all the way, only to complain that it is in a different vesion.
All you should have to do is to open the app in WindowMaker. It'll complain that it's an older version, ask if you want to upgrade.
Usually, with an Access Denied message, you're working with a copy that you made from a CD, which had the Read-Only attribute set. Go to the app folder with Windows Explorer, right-click on the folder, and uncheck the Read-Only attribute.
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
138
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
133
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
172
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
106
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
149
