Intouch ... warning "need to run db.exe"
HenkieD
Jul 2006
Durbs
62
Hi All,
When I was busy sorting out the tags on a window that I just imported (changing from ?D:Tagxyz to Tagxyz, only had 10 tags, so to little to do a dbdump) in widowmaker, the app just froze, I gave it a couple of minutes but eventually I had to kill it. After restarting widowmaker (and deleting appedit.lok), it comes up with a warning "need to run db.exe", and after pressing ok it also gives a couple of reading errors, refering to those ?D:Tags. I have tried to delete the just imported window, but it doesn't allow and hangs when I try to do so.
All the other windows and scripting seems to be intact...
Any suggestions...
Thanks in advance
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
152
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
91
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
