ir sensor
derekw
Dec 2004
Hello.
I have been trying to get a Raytek Thermalert 6 system to measure temperature of molten iron. about 2500 degrees F
In the menu choices of this device
I have selected the external device as 'none' and an emmisivity of .10.
Should I be selecting the appropriate tc as the external device? Even tho it is not actually a thermocouple?
The device is showing a temperature 30 degrees F higher than it should.
As i have no documentation for this device(s), I am at a loss.
I will try to contact Raytek regarding this model. But they no longer list it as a product for sale.
thank you,
derek
Forgive me but it's been awhile since chemistry class, but I thought the emissivity of molten iron would be higher than that?
thanks for the link. can the emissivity setting be used to scale this device to read correctly. i was hoping somebody would be familiar with this particular device pictured.
thanks
Not familiar with that particular device, but what seems odd is that 30F isn't that far off, so if you change the emissivity to a range that molten iron is supposed to be at (around .29) I think that the reading would be farther off.
yes, i think if the emissivity is changed to .3 from .1 the reading would be farther off. also, i made a mistake in the posting. the reading is much further off than 30 degrees. it is reading 3000 instead of 2500.
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
76
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
116
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
216
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
173
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
233
