Is Codesys broken wrt the Left-to-Right, Top-to-Bottom convention for Ladder in some cases?
I also do not get the same results as the original post. I am using Windows.
Also Brian, I do not understand how your compiler lets to assign ton0.Q to a coil. ton0.Q is an output of the timer on FB, so I got an error when I tried to build my program as shown in your post.
although it should be possible in any sane PLC programming environment (as it's only a memory bit, so why not), ton0.Q is not assigned to a coil in my program.
My program declares a BOOL called ton0Q (not ton0.Q) and uses it to map the timer-expired state, just in case the Codesys timer functions work in the same (IMNSHO) poorly-designed fashion as Siemens timer functions i.e. evaluate the timer object's internal state at each reference to the object asynchronously with the TON instruction.
Oh, I did not see that...
But anyways, I cannot reproduce your results.
Can reproduce with Ladder (LD2) but not with Ladder Logic Diagram (LD).
I don't have the wording of IEC-61131-3 on ladder execution order, but it does contradict codesys's help page 'A branch splits the processing line into two or more branches which are executed in succession from top to bottom.'.
I would say it is a bug in the new ladder, report it to CODESYS Store North America > My Question > Bug Report.
Always anticipate bugs with anything at version 1.0.0.0
If you go to installer, change, browse, search, you can search for LD to install the old ladder.
I was surprised when I saw the new Ladder. In the version that I use it does not show as "LD2". I guess for the latest version they changed the name to somewhat distinguish it. I find the new LD2 difficult to use. Perhaps I am so used to the other.
I wonder why this was introduced in CODESYS.
I am also not a fan, takes more time to program, too many places to click in a network.
I do find it similar although somehow worse than TIAs ladder editor.
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
303
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
93
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
163
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
517
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
182
