Is SQL Server OPC Client compliant?
greg71
Jan 2007
PA
I have a client that is running Microsoft SQL Server on the computer, and logging some live data. Now, he wants to connect this PC to a modicon PLC via modem, and say use the Kepware OPC server with Modbus driver to read the data from the PLC. But, he would like to also write some data from the SQL Server into this PLC. He doesn't need the full blown HMI application for it; all what we need is to write periodically one value from SQL Server into OPC Server/PLC. I understand that this SQL server has to act like an OPC client; is this correct?
TIA
Greg
Greg,
Kepware also has a driver that is part of their KepserverEX product called ODBC, which is an interface for databases.
You can download the manual through the following link:
http://www.eternity-sales.com/Kepware/kepwaredownloads.htm
It is entitled - ODBC Client Driver OPC Server Suite
If you find that you will be in need of a third driver, I would suggest the Manufacturing Suite in that it will be less expensive than purchasing three drivers individually.
http://www.eternity-sales.com/kepware/serverbundles-ms.htm
Hope this helps.
Shalom and God Bless,
Hey Everyone, I am using FTView ME (unfortunately.) I am trying for the first time, to pull data from an existing SQL server (not mine) to...
3,616
Hello, I have problem with set up some sofware to collect data. I have: - GE Fanuc with program - TopServer for getting information from PLC And...
11,807
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
158
Hi, All: I have a project to replace 3 old window 7 PCs with new window 10 PCs. the 3 old PCs: one is FTV SE server, other 2 are SE clients...
584
Hi everyone, I have a small project where I need to use plc to get sensor data and log them to an sql server locally or remote. I have found...
2,852
