Is there a "bit and" or "bit or" in lookoutdirect?
AlecTek
Sep 2010
Vancouver
155
Does anybody knows how to make "bit and" or "bit or" in lookoutdirect 4.5? I stored bit info in the words of PLC V-memories, but I just could figure out how to set/read them from lookout. &,&&,and don't work. Thanks.
They don't use ampersands. Just use the word AND as in; (Expression1 AND 2). Of course, you could substitute an expression in place of the '2'.
Does anybody knows how to make "bit and" or "bit or" in lookoutdirect 4.5? I stored bit info in the words of PLC V-memories, but I just could NOT figure out how to set/read them from lookout. &,&&,and don't work. Thanks.
Sorry I missed the "NOT".
I was a fool that I programmed the PLC with all logics with bit operations in the V-memory, and now I've found LookoutDirect doesn't support bit operation. I tried hard to display the bits with expressions like: if(Mod(Int(V3000/8),2),TRUE, FALSE), and now I am able to display them, but still not knowing how to set them.:mad:
Thanks, Doug, but the AND is not a bit and, (1001 AND 0011 = true)
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
292
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
228
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
78
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
166
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
149
