Issue with IP configuration of compact logix
rejoe.koshy
Dec 2011
kolkata
195
hey guys,
I have L32E compact logix processor installed in my facility & it happened to fail abruptly.Subsequently I replaced it with a new processor & then updated the firmware & downloaded the program.
Now I notice that whenever I recycle power the "MS" led on the controller flashes green for a while & then becomes steady , post which the link LED starts blinking & ethernet communication begins.
This was not the case with the previous controller.I tried assigning IP with BOOTP & RSLOGIX 5000 but to no avail!...
Refered to the manual & it says "contoller does not have IP, verify BOOTP server is running"..
Pls help!!!
I have tried doing that but didnt see any difference! I dont know whether its the switch the controller is connected to or the ethernet cables!!..no idea at all
You can set the address with DHCP but it won't necessarily stick unless you go online to the processor use the the Set IP command and untick the DHCP and BootP options.
Sometimes turning it off from the DHCP server works, but not always.
Hey guys! I have come across an unique issue. Hoping that I can find some solution here. I want to replace an existing S7-1214 DC/DC/DC plc with...
4,776
I have DeviceNet network connected with controllogix PLC by Scanner 1769-SDN . I Have backup for all drives and flex I/O connected over this...
1,425
Hello all, In my current project I am using Allen Bradley 1769 High Speed Counter with Compactlogix PLC and IO modules. The High Speed Counter is...
3,378
I have a copy of RSLogix 5000, RSEmulate 5000, and RSLinx Classic all installed and working on my laptop. In the past I've created a number of...
2,691
We are using Allen Bradly DI module 1756-IB32/B in one of my projects. I'm facing an issue (I'm getting 25 VDC from some of the inputs channels)...
16
