Issue with RSLinx & Excel
almog44
Oct 2015
Israel
26
I use dde/OPC to read tag vaule in excel file
its working ok when rslinx running NOT as service
but when I run rslinx as service I got an error at excel:
"Remote data is not accessible."
how can I fix it, I need the rslinx run as service
I seem to remember a problem like this before having to do with the application name when running as a service. You don't use rslinx but something else. If you have a tech connect account I would search there or call tech support.
Using a quick search here is a public answer:
RSLinx Classic and Terminal Services/Remote Desktop 68346 | Date Created: 05/03/2010 | Last Updated: 07/01/2019
Access Level: Everyone
Another answer (#533000) that came up is tech connect level only. But states that they no longer support DDE in Windows 7 and OPC has to be used.
They also suggest using the OPC test client. If it works when running as a service then you should be okay. If not then they blame Microsoft (typical).
When running an application as a service it is running as a local system user under session 0. Desktop applications run as the logged in user in Session 1 or higher. Because these are different sessions and accounts the connection has to be made using NetDDE which Microsoft deprecated and is no longer available in Windows 7 and higher. It was removed for security purposes.
I'm trying to create a DDE Link betweek RSLinx and Excel. I've done this before without issues, but I'm getting a pop-up when I open the Excel...
5,457
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,786
Hello Team! Glad to join your group! I am stuck on an connectivity issue I am having with a customers PLC I am trying to help troubleshoot machine...
1,379
I have just downloaded and installed CCW software which upgraded my RSLinx to version 4.11. This has caused me a problem and I was wondering if...
2,567
Good Day All, I have a strange problem with the new Powerflex 525 6.001 with RSLinx 4.11. No matter what I do I cannot get RSLinx to show up the...
7,905
