issues with studio 5000 and CCW after PC upgrade
6speedblazer
Jul 2019
missouri
Hello All, I recently had my 4 year old work PC crash and IT set me up with a new PC that has windows 11 pro and a 4k display.
I have had a ton of issues regarding the 4k display with most of the programs I used. I had to go into compatibility mode and change the settings for those specific programs. Doing so solved 90% of my issues in both Studio 5000 and CCW. However, I still have a few minor annoyances I can't seem to sort out.
in CCW my rung comments are so small I can't see read them. If I'm offline I can edit the comments and they pop up to full size readable text. Everything else appears to look and function as normal for ccw environment. attached is a screen shot showing this issue.
In studio 5000 a lot of my icons are very small and overlapped, plus I cannot select other language elements to be able to see other ladder elements. the last issues is in my controller tags the drop-down carrot does not work. I have to right click and selected expand or contract to see all the elements in the tag.
thanks for any help on this.
That is interesting, I work using dual 4k displays, and do not have that issue with Studio 5000. I have not used CCW for anything other than VFDs, so I cannot say if I have the same issue with the logic comments.
Im only assuming its something with the scaling and the 4k monitor. Changing that fixed similar issues i was having in autocad with toolbars.
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
74
Hello All, I am hoping for some help. I have a 1756-L84ES which must communicate with an ArmorStart 281-F12S-10B (Series A, Rev. 2.1). Typically I...
828
In this routine, i have an issue where when "lineSpeed" is changed, the PID loop math does not appear to be working out correctly and if I'm only...
2,713
HEY GUYS so i just built my 3rd plc trainer compactlogix 5069-L3069ER. It was brand new out of the box set up i have my ip address set up i...
17
6,069
I recently upgraded to Studio v31 and now other people are unable to restore my APA file from FTView 9.0 unless they are also on v31. Something...
1,957
