Jam on the line!!
Just Jo
Apr 2016
uk
Logix 500 question
Hello, I am a newbie on here so please be gentle!!
I have been given a project to detect product jams on a conveyor system.
The conveyor already has 5 pec's on it to operate brakes as the line fills up. The brakes then open in sequence to release product to the next machine downstream. The logic would be that if any downstream pec is false ( no product) and an upstream one is true then an alarm would be activated.
I could do it with n/o n/c contacts but with 32 possibilities I need a neater version.
any ideas would be most helpful
regards
Jo
My advice is that if you are new to PLC, DO NOT try to be clever; do it in whatever long but straight-forward form first and test it. Once you do that, we can suggest a few ways to shrink the code down.
Imagine looking at PEC5. Now state the logic using this as a starting point.
If this PEC is ON then you don't need to worry about it.
But if it is OFF then what other conditions would trigger an alarm?
"If PEC 5 is OFF AND ..... then alarm" What goes in the '.....'?
Thank you for the support guys, I had thought about using the inputs to generate a binary number, so I had a cup of tea and drawing up a truth table there are only 6 outcomes that are favourable (not jammed) which makes it a whole lot easier.
I have product going on conveyor. In order to detect jam, If photo eye does not see a gap between each product for certain time, it thinks there...
38
10,771
The Mitsubishi FRA520 frequency inverter: I have the P 5 set to default 30 Hz and the low speed P 6 set to 10(HZ) which kicks in after hitting the...
1,789
I had this project thrust upon me when the guy in charge got suspended. It is my first exposure to Rslogix 500 and the 1400a PLC. I know that the...
1,891
I'm progressing but have hit another snag. I'm programming an AB 1400a and am using an Integer file N10 to store pulse counts. Is there a way to...
1,584
I posted a new guy type question in an earlier thread. I have a follow up none related question. Is there a Allen Bradley "address knowledge" for...
1,865
