^that is the way i always do it. Its significantly faster/easier than searching through all the tabs and trying to find the JSR one anyway.
Do you really use the tabs to find instructions?
Have you tried pressing the Insert key on your keyboard?
Try it, then start typing the instruction mnemonic, as soon as the box shows the instruction you want, just hit enter. Nothing else, just hit insert, then key in J, the display will go straight to JMP - then hit S, the display goes to JSR, hit enter, and job done. In most cases, you only need to press the first letter of the instruction mnemonic, some cases 2, and rarely 3.
I never use the multiple tabs of the Instruction Element Toolbar - it's tedious.....
