tarrant79
Hi, I am dealing with a single SBR subroutine thats handed 1 input paramter UDT P.x multiple times: (Pump) P.1/2/3/4/5. I JSR into the same routine for all pumps with handing it INPUT=P.x and RET=P.x so I process the UDT P.x for each index and then update the P.x with the return parameter. The only problem is I can only see the last index into the called subroutine to troubleshoot.
Ive been getting around it by, running all JSRs, and then coming back around to do a 2nd JSR call for whatever Pump I'm trying to troubleshoot. I just figure theres got to be a better way....
JSR Pump_xx 1 P[1] P[1]
JSR Pump_xx 1 P[2] P[2]
JSR Pump_xx 1 P[3] P[3]
JSR Pump_xx 1 P[2] P[2] =To see Pump[2] executed in the routine Pump_xx to troubleshoot.
