Rslogix5000 how to troubleshoot indexing JSR
tarrant79
Jun 2020
washington
23
Hi, I am dealing with a single SBR subroutine thats handed 1 input paramter UDT P.x multiple times: (Pump) P.1/2/3/4/5. I JSR into the same routine for all pumps with handing it INPUT=P.x and RET=P.x so I process the UDT P.x for each index and then update the P.x with the return parameter. The only problem is I can only see the last index into the called subroutine to troubleshoot.
Ive been getting around it by, running all JSRs, and then coming back around to do a 2nd JSR call for whatever Pump I'm trying to troubleshoot. I just figure theres got to be a better way....
JSR Pump_xx 1 P[1] P[1]
JSR Pump_xx 1 P[2] P[2]
JSR Pump_xx 1 P[3] P[3]
JSR Pump_xx 1 P[2] P[2] =To see Pump[2] executed in the routine Pump_xx to troubleshoot.
In the OldenDays (*), we used to put StatusFlagBits in multi-used routines, for situations like this. Its tempting to leave such troubleshooting/de-bugging stuff out, when you develop...but at the first glitch makes it worth it.
(*) FORTRAN 4
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
176
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
179
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
487
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,152
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
909
